Delete for the specified tunnel could not be initiated.
Check if the tunnel still exists. If it does and is a dynamic entry, then check whether the I/O or MM is busy. If the above is an issue, please notify the administrator with exact detail of the config, the tunnel paramters viz. MAC, vlan-tag, port that is having the problem.
Warning
Error while initiating delete for Outer MAC %MAC%, vlan %vlanId%, port %slotPort%, tunnel %tunnelId%.
| Name | Type |
| MAC | MAC |
| vlanId | VLAN-tag |
| slotPort | uInt32 |
| tunnelId | uInt32 |
